1978 - 1996 Big Bronco
bleeding brakes
Old Nov 20, 2004 | 03:32 PM
openscars's Avatar
openscars
Exclamation bleeding brakes
I've got 79 bronco and i went to bleed my brakes but i cant break the bleeder screw. i also ended up rounding it too. hows the best way i can break it?
Old Nov 20, 2004 | 03:52 PM
dcotton's Avatar
dcotton
I always use a socket to break it loose, at this point I would use vicegrips and then replace the bleeder.
D
Old Nov 20, 2004 | 05:13 PM
JBronco's Avatar
JBronco
Small vice grips to remove the bleeder, then replace it. Spray some penetrating oil on it first, before trying to get it out.
Old Nov 20, 2004 | 05:25 PM
JBronco's Avatar
JBronco
Oops...just what dcotton said!
Old Nov 20, 2004 | 06:25 PM
jacque_strap's Avatar
jacque_strap
Give it a few blows with a hammer, directly on the *head (top), to break the threads free. A source of heat (torch) would help, don't know what you've got but I'm sure you can get it without anyway.
Old Nov 20, 2004 | 06:32 PM
aurgathor's Avatar
aurgathor
If you got time, soak it overnight with PB Blaster. Then follow what was said before -- lightly hammer the head, you can also try to hammer on a socket, and use that one instead of the vicegrip.
Old Nov 20, 2004 | 09:16 PM
tom2131968's Avatar
tom2131968
Whole calipers are cheap too...I replace mine as a matter of habit anyway every three years or so.
Tom T
