Steering
Old Nov 20, 2004 | 01:45 PM
wickymustang's Avatar
wickymustang
Steering
I have a 1995 F150 2wd, I was greasing my tie rod ends and steering linkages, but I can't get my grease gun onto the fitting for the inner tie rod end, because the grease zerk is pointing to the rear of the truck and the cross member is right there. Any ideas??
Old Nov 20, 2004 | 03:35 PM
ATC_250SX's Avatar
ATC_250SX
if you steer it form one side to the other can you get it? maby jack it up by the frame?? i cant think of much else, i can get to all of mine on my f-150 4x4.
Old Nov 20, 2004 | 06:05 PM
SRD4X4's Avatar
SRD4X4
Grab tie-rod and pivot it downwards.Assuming your grease gun has a hose,if it has a "solid" tube-type end,this might not work.
Old Nov 20, 2004 | 07:11 PM
wickymustang
I thought the tie rod wasn't supposed to pivot up and down when it is all connected and working right.
Old Nov 20, 2004 | 07:24 PM
SRD4X4's Avatar
SRD4X4
Tie-rods and balljoints are designed to move in any direction.End play is what you don't want.
