drive train vibration
Old Mar 5, 2002 | 12:16 PM
CobraXP's Avatar
CobraXP
Old Mar 17, 2002 | 07:42 PM
rangerdad96's Avatar
rangerdad96
Post drive train vibration
I have a 96 ranger supercab with 4.0 and auto trans. purchased new. It has 62,000 miles. Never changed the trans fluid. I get a slight vibration at idle and low speeds it seems to fade in and out. At 70 miles per it is more pronounced but it also comes and goes. I have had new tires installed and balanced with no change in simtoms. The problem seemed to develope at about 40,000 miles. Anyone have any ideas?
Larry
Old Mar 18, 2002 | 09:18 AM
Ken00's Avatar
Ken00
If you mean you are parked when you feel it at idle I would look at the engine for a vibration. For a vibration at speed I would look at the driveshaft balance or the u joints if the tires are not an issue. If you put it in neutral see if it goes away, this will eliminate anything up stream.
