Sponsored by: Auxito
driveshaft noise
Old Nov 20, 2004 | 09:56 AM
97texan's Avatar
97texan
driveshaft noise
I have a 97f150 4x4, when I take off from dead stop I hear a noise that sounds like it is coming from driveshaft , if I accellerate slowly there is no noise.Can anyone help?
Old Nov 20, 2004 | 10:17 AM
97texan's Avatar
97texan
I think this might be the slip yoke problem that someone else posted.
Old Nov 21, 2004 | 12:41 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
The noise you're hearing quite likely is the slip yoke probem but you could also have a bad U-joint. If you remove the shaft to lube the slip yoke you can carefully check the U-joints to make sure they don't have any play in them or that they aren't seized.
Old Nov 21, 2004 | 12:52 PM
wgotthardt's Avatar
wgotthardt
97Texan,
Here's the thread...
https://www.ford-trucks.com/forums/s...d.php?t=308004
Cheers, Wm.
