302 plug wires arcing, causes?
Old Nov 20, 2004 | 01:21 AM
packrat56's Avatar
packrat56
I have been having a bad miss for months, replacing everything.
Put some good Moroso Blue Max Spiral Core wires on, replacing other new, but inexpensive wires. I had major arcing between the black caps that go onto the distributor. If they got to within 1/8 or so they would arc with a bright blue continous spark. I managed to turn them all "just so" to eliminate the arcing, HOWEVER; I do not see this as normal? What is it a possible indication of? Wrong coil? Ballast resistor problem? ?? ?? ?? Could it be the cause of my miss all along even when there is no arcing, just as an indicator of a problem?
73' 302, stock distributor with a magnetic pickup points replacement unit, coil unknown but looks cheap, ballast resistor old, but working (I think)
Any ideas appreciated!!
Thanks.
Old Nov 20, 2004 | 06:42 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
arcing problems
Hey packrat56.If you had arcing problems with old high resistance wires you may have carbon tracking on the cap. Even with new wires the carbon track would have less resistance than the plug gap. This may be a good time to replace the cap and rotor. Carl......o&o>........
Old Nov 20, 2004 | 06:47 AM
"Beemer Nut"
gap and replace plugs
Packrat56, sorry i forgot to mention on the last post, did you gap and install new plugs? That would be a bad thing missing for months like you stated.
Old Nov 20, 2004 | 11:12 PM
Franklin2's Avatar
Franklin2
Yes, if the gaps are too large on the plugs, the spark will be more willing to jump somewhere else other than the large gap at the plug.
Old Nov 23, 2004 | 11:31 PM
packrat56's Avatar
packrat56
Everything checked out fine, so I called Moroso. The "have been having some problems" with these wires..(why did they ship them??) Anyway, I sent them back and they will send a new set, hope they are better...
Old Nov 24, 2004 | 11:45 AM
73Custom's Avatar
73Custom
Be sure to use some dielectric grease in both ends of the wires. this will provide a good clean connection and lessen the chances of arcs.
Marty
Old Nov 24, 2004 | 11:51 AM
packrat56's Avatar
packrat56
Thanks 73custom, Ill do that.
