nuetral saftey
Old Nov 19, 2004 | 10:03 PM
smoke n tires's Avatar
smoke n tires
neutral saftey, help
help, i cant get my neutral start switch adjusted on my c6. i just resealed the pump and reinstalled the trans. i think my switch is off cuz the truck sometimes wont even try to turn over and i removed the switch when i pulled the trans. if anyone can help me with adjustment procedures id appreciate it.
Old Nov 19, 2004 | 10:27 PM
smoke n tires
nuetral saftey
can anyone tell me how to adjust the nuetral saftey switch on a c6? i removed mine and cant get it back in adjustment.
Old Nov 21, 2004 | 01:10 AM
Chiefrider007's Avatar
Chiefrider007
Put it on loose, truck in Neutral, insert a small pin in the center hole. Here's the catch, there's three sections in the switch, top, middle, bottom, anyway, the pin has to go through all three sections. You can move it with the bolts loose to insert the pin, it should go in something like 1/2 inch or a little more. Once through, tighten the bolts and your got er done.
If you need more specific instructions, let me know.
Moooboy
Sep 22, 2016 08:04 PM
quadrazer
Nov 23, 2012 10:54 AM
svemike
15
Jan 21, 2011 04:28 AM
Chevy Sucks
Feb 17, 2006 09:13 PM
76supercab2
Aug 29, 2005 07:24 AM
