Modular V10 (6.8l)
V10 Spark plug blow out?
Old Nov 19, 2004 | 05:41 PM
guruatbol's Avatar
guruatbol
Thumbs down V10 Spark plug blow out?
I just had one at 76K...anyone else have one during the time they owned a V10? How many miles was on the engine?
Mel
Old Nov 19, 2004 | 07:53 PM
cburgess's Avatar
cburgess
You can do a search on this forum and you will find a lot of discussions and opinions. While it hasn't happened to me (knock on wood at 55K miles), I am very paranoid about it.
Just curious based on my previous research -- the plug that blew, which one was it? And are they the plugs that came with the vehicle or have they been changed recently?
Here are a couple links that might help:
Popular (and relatively inexpensive) Time-Cert repair kit:
http://www.timesert.com/sprksert.html
Old Dec 6, 2004 | 08:25 PM
darek's Avatar
darek
I'm a new owner of a 2001 F250 crewcab 4x2 with the V10 and I to am a little concerned with this issue. My truck has 34k miles.
I bought a very good extended warranty through my credit union but I need to check to see if it would cover something like this.
From what I read, if you change them at 50k the problem is drastically reduced.
Heck, I'll just change them every 30k or so....
Old Dec 6, 2004 | 11:48 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Make sure you torque them correctly!!!
That is the most critical bit...
Old Dec 7, 2004 | 05:48 AM
darek's Avatar
darek
If we all have the dealership do it, (or actually any mechanic) than I would be concerned with "trusting" that "they" torqued them to proper specs...
Does anyone agree that that is a valid concern?
I will buy a nice TQ wrench so that atleast I can double check...
Old Dec 7, 2004 | 07:27 AM
SLE's Avatar
SLE
What year is your truck - I'm just curious if this is still a problems on the 03's. I believe I read somewhere that they increased the amount of threads on the 02's and newer - I'm not positive on this so if somebody would like to clear the water feel free - If I'm right with the increased threads has the problem been solved or is it still happening.
Old Dec 7, 2004 | 09:15 AM
guruatbol's Avatar
guruatbol
After gathering more info, I have discovered that the 99-02 V10s and V8s are the ones in question....
If you guys want to know if your extended warranty will cover it, then just call them and ask...I got what I thought was an outstanding warranty from my credit union as well...
The Warranty company finally relented and payed for the parts, $1531.00...they labor is on me....
I sent a letter to Ford and we'll see what happens...I may just have to buy other than Ford corporate vehicles....
Mel
Old Dec 7, 2004 | 10:05 AM
cburgess's Avatar
cburgess
This is a topic that has been hashed and bashed all over this forum and others.
Here are a few links within this forum:
Great discussion on topic:
https://www.ford-trucks.com/forums/s...d.php?t=255793
Great discussion on changing them yourself:
Some more related links:
https://www.ford-trucks.com/forums/s...d.php?t=288263
https://www.ford-trucks.com/forums/s...d.php?t=283836
https://www.ford-trucks.com/forums/s...d.php?t=274979
The extra threads don't make any difference when the Ford engine head is designed like this (from autolite's web site):
http://www.autolite.com/tech/Half_FullThread.pdf
I haven't seen anything (except opinons) as to whether Ford has changed the head design. From what I have read/seen, it is designed this way at least from 99-02.
From all the posts I have read on the subject (trust me I have read a lot on this subject), extended warranties are most likely NOT going to cover it. I can only recall one post where the person said their extended warranty covered parts and labor with no hassle. Either it is not covered (period). Or like guruatbol, they had to fight to get some/all covered.
I would advocate doing it yourself (see the link about changing it yourself). I have read several posts where the plug blew shortly after a change or, because a couple of the plugs are hard to get to, the owner discovered not all plugs were changed.
But when you do it yourself, you MUST have a good torque wrench. That is your best defense: correctly torqued plugs. Torque 'em right when you change them. And check them peridodically.
If you do have a blow, I have read nothing but good things about the time-sert repair, and it is 10% of the cost of changing the head.
'nuff said. Read (lots) more in the links above, and I am sure others will chime in.
