brake lights???
Old Nov 19, 2004 | 03:22 PM
triggerjoe's Avatar
triggerjoe
brake lights???
The brake lights on my 79 f100 have mysteriously started popping on again...
Old Nov 19, 2004 | 03:37 PM
RR4E's Avatar
RR4E
Broken wire at the brake light switch? It's located near the brake pedal, might be to close or to far away, could be a broken wire, could be just about anything in between.
Old Nov 20, 2004 | 10:02 PM
arcticoffroadingfish's Avatar
this may seem stupid but is the switch stickin or geting caught on the metal plate cuz mine does that a lot so im reachin down and knockin it loose off the metal plate.
Old Nov 21, 2004 | 12:53 PM
73Custom's Avatar
73Custom
Usually it's a faulty switch or a problem with the brakes that allows the pedal to drop down when not in use. Next time you notice the lights are on, look at the brake pedal, notice if the pedal has dropped, allowing the switch to come one...
Marty
Old Nov 21, 2004 | 08:13 PM
alumataz22's Avatar
alumataz22
I dont know if your brakes are set up the same as mine but my brake light was coming on on my 77 f-250 and I pulled the master cylinder of off the vacuum booster and there is a rod that sticks out of the front of the vacuum booster that pushes on the master cylinder, the front of the rod has a threaded nub on it and I screwed that nub out a couple of turns and it cured my problem.
Old Nov 21, 2004 | 08:34 PM
Mil1ion's Avatar
Mil1ion
Do you have cruise control ?
If you don't disregard this post
If you do, it matters
Old Nov 21, 2004 | 08:48 PM
Colo79Ford's Avatar
Colo79Ford
Are the light bulbs popping, or are the brake lights flickering? If the bulbs are popping, is the fuse right? If theyre flickering the cause has probobally been pointed out above. My lights flickered, and were spuratic, ended up the Mag the highway department lays down was eating away at some exposed connections under the truck. But id rather replace wiring than have someone run into me.
--John
