Battery terminal getting corroded....
Old Nov 19, 2004 | 01:27 PM
Ford_NDN's Avatar
Ford_NDN
I have a Ford F-150 '94 and I am having trouble with the battery terminals. The truck won't start sometimes and when I clean off the battery terminals the truck will immediately startup, it doesn't need to be jumped. The terminals are covered in a white substance and this comes off easily. However after I clean the white stuff off the terminals are sort of a dull silver/gray color, not the bright color that they should be. The truck will only start after I clean off the terminals and they are shiny again. It only happens maybe once every three/four months, but I have my father who is in his upper seventies drive the truck and I don't want him to have to clean them off one night about 8 o'clock in the freezing rain, etc.,etc.. I would like to know what is happening and how to stop it from happening, so that I don't have to keep cleaning the terminals so often.
Old Nov 19, 2004 | 02:04 PM
Frank Lang's Avatar
Frank Lang
I'm no mechanic, but I have always coated battery terminals with vaseline or some kind of grease, and that apparently keeps them from doing this. However, next time you clean them, also neutralize them by brushing them with baking soda until it doesn't fiz anymore, then rinse with plain water, then dry and then coat with whatever grease/vaseline you plan to use. Unless your battery is faulty, that should fix the problem.
Hope that helps. Others may have advice too.
Frank
Old Nov 19, 2004 | 03:02 PM
wickymustang's Avatar
wickymustang
Go to checker auto, and get 2 things. One is a can of nuetralizer, basically a stronger version of baking soda. Clean the battery, terminals, cables, and tray with this. Then reconnect the terminals on the battery and coat them with the protectant that comes in a tube. It is meant to nuetralize any acid, and stops it from forming.
Old Nov 19, 2004 | 07:32 PM
peppy's Avatar
peppy
I didnt understand it myself. I had the same problems. Then it wouldnt start. Took the battery in. Tested fully charged, yet only 100 of 750 amps. Replaced the terminal and cable.
End of problem. Well, and on to the next.
Old Nov 19, 2004 | 07:40 PM
triton_2002's Avatar
triton_2002
I use those red and green felt pads that fit around the battery post and some electrical grease. Never had a problem.
Old Nov 19, 2004 | 10:46 PM
MemOrex's Avatar
MemOrex
Just buy new terminals for like 2 bucks. I just replaced my ground one with wires and all for around $5.
Old Feb 22, 2007 | 09:44 PM
Robert Churchill's Avatar
Robert Churchill
corroded terminals
Switch to a sealed Optima red top battery. You will never have a corroded terminal, cable or battery tray again.
Old Feb 22, 2007 | 10:14 PM
dave2's Avatar
dave2
Next time you clean things up, lay a penny or two in the middle of the battery (maybe wedge it between the caps to keep it from bouncing off). corrosion will go to the penny (s) and not your terminals. Just clean or throw away the penny when it's full. Cost you about ten cents a year at the most, and no more work. Never had a penny damage a battery.
Good Luck,
Dave
Old Feb 23, 2007 | 11:25 AM
Dukernc's Avatar
Dukernc
I would just clean the battery posts, terminals and cable ends with a wire brush or battery post cleaner. Then reconnect the terminals to the battery post and spray the terminals and posts with a good coat of spray paint. This coats the battey posts and terminals helps to keep them clean and seals them from any acid forming. I've been doing this for years and it works for me!
Regards,
Dukernc
1999 F-350 CC Lariat Dually LB 7.3L, 6 speed, 4.10, Linex bed liner, 4" Magnaflow SST turboback exhaust w/ 5" tip
1990 F-150 XLT Lariat 4X4 SB 5.0 EFI, 3.55LS, Modified AOD w/auxiliary cooler, cat back, all around farm truck
