solid shift opinions
Old Nov 19, 2004 | 12:30 PM
thinksnow's Avatar
thinksnow
I upgraded to a triple lock T/C and put in a factory tech valve body. Im also running a SCMT. The shifts are solid to say the least. I'm wondering if I should switch over to a Diablo since it gives you the option of not raising the line pressure electronically. I'm thinking leaving the line pressure at the stock setting on the Diablo might back the shift firmness down a hair or two?
Old Nov 19, 2004 | 02:08 PM
Fire Rooster's Avatar
Fire Rooster
Check around see if any of your friends have a diablo that you can borrow for a few days and try it before you buy it. I sounds like a good idea though.
fire rooster
