instr. cluster , door chime, interior light
Old Mar 26, 2002 | 12:04 PM
onebad40willys's Avatar
onebad40willys
First of is it possible to replace the 97 cluster w/o tach, to one with the Tach ? The door chime likes to ring while im driving on the highway every once and a while when i hit a little bump? Last has anyone found a fix for the switch in the door jamb, such as using an older or newer one?
Old Mar 27, 2002 | 01:51 PM
Ken00's Avatar
Ken00
The instrument cluster should be an easy swap, I'm not sure if it will cause a problem if you get one from an engine with a different number of cylinders. The door switch is in the door latch, clean it with electrical contact cleaner, others have said you can just spray the latch with WD-40.
Old Mar 27, 2002 | 01:55 PM
Ken00's Avatar
Ken00
