Shortening the Frame
Old Nov 18, 2004 | 05:48 PM
79pos's Avatar
79pos
I have a 79 4x4 longbed. I need a cab and a bed but the only replacments I can find are shortbeds. Is it possible to shorten the frame to fit or is this a bad idea altogether.
Old Nov 18, 2004 | 06:03 PM
john7979's Avatar
john7979
Its not a good idea it can cause all kinds of problems and isn't really safe to do unless your a good welder. It would be easier to keep looking until you find a decent long bed.
Old Nov 18, 2004 | 06:06 PM
74 F100 351m's Avatar
74 F100 351m
If the floor is ok, just buy bed sides.
Old Nov 18, 2004 | 06:39 PM
ivanribic's Avatar
ivanribic
So odd . . . ALL the trucks around here are longbeds. Seems I never see a shortbed at the bone yard.
What I have seen done before, and this may only work with a lift, is I've seen the back of the frame chopped off and the spring hangers moved forward to center themselves in the wheel wells of the short box. There's a slight "hump" to the frame over the wheel but if the truck is lifted a little that's not an issue really. It saves trying to cut and reweld the frame in the middle so you don't have to worry about it cracking on you. I'm not sure, however, if the crossrails under the bed will sit correctly or not. You'd have to take measurements and see . . . might need a body lift to clear the high spot in the frame.
Old Nov 19, 2004 | 09:20 AM
mpcrewcab's Avatar
mpcrewcab
Its not hard but your a long way from WI or I would help you. A day of work and its good. I agree shortbeds are in SHORT supply as most longbeds and everyone wants a shortbox.
Old Nov 19, 2004 | 05:05 PM
haten'chevs's Avatar
haten'chevs
My neighbor and I did this to his 78'. He had a longbox and wanted a shortbox. Luckily a relative gave him a 78' shorty that was in pretty sad shape. Had been on a plow its entire life and the frame was shot or we would have used it, but it made a excellent template. We measured, measured again. We made the cuts with a sawsall (in the middel of the frame) slid the 1/2s together and tacked them. We then made plates for the inside of the frame (1/2") that fit EXACTLY. Then we measured again and tacked them in then welded in a cetain spot on one side and then in that same spot on other side. After every weld we measured. Did I mention we measured alot?? We were probably more careful then we needed to be, but OH well.
Old Nov 20, 2004 | 12:35 AM
olfordsnstone's Avatar
olfordsnstone
Maybe, Flat Bed?
Old Nov 20, 2004 | 12:45 AM
ivanribic's Avatar
ivanribic
If you decide to cut the frame and weld it be sure to cut diagonal. This gives you much more area to weld making for a stronger joint. Cutting vertically straight through the frame is a bad idea and not a terribly strong setup when complete. The extra plates like Haten suggested are a good idea but use some sort of sealant all over the back before welding or bolting them in place. Otherwise water gets between there and the frame and starts rusting it away.
Old Nov 23, 2004 | 12:49 AM
dwbachor's Avatar
dwbachor
See if you can locate a IHC scout, and have a look at the frame (mid 70's).They have a tube frame but the splice could be easily incorperated on a channel frame. International made their frames in sections for different wheel bases.
Old Nov 23, 2004 | 04:52 PM
1320stang's Avatar
1320stang
How about putting a Supercab on there with the shortbed? Get some more interior storage that way.
Larry
Old Nov 23, 2004 | 05:37 PM
79pos's Avatar
79pos
With a supercab shortbed would the frame be long enough.
Old Nov 23, 2004 | 08:08 PM
ivanribic's Avatar
ivanribic
I believe the Supercab/shortbed combo is too long for the regular cab/longbed frame. Plus I don't know that it makes much sense to completely rebuild the whole truck just for a beat up bed.
Old Nov 23, 2004 | 08:35 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
im not positive but i beleive the short bed supercab frame is the same as the singlecab longbed.....but i have this catalog that has every body part for the 73-79 ford trucks...in it you can buy the separate pieces for the bed i.e.side panels,bed floor, tailgate and hardware.....i might get yelled at for posting it (im not familiar with all the FTE rules...)but the name of the catalog is LMC trucks....they are free catalogs....i got mine at www.LMCtrucks.com they mail them at no charge....i was really impressed with the selection.....they cover these trucks bumper to bumper......sorry if i bent the rules....
ADMIN NOTE: Please spare us the coy comments... you've been here over a year, you purposely mask a web address and then say you're not familiar with the FTE rules? Link fixed.
SwOkcOffRoader
Old Nov 23, 2004 | 08:48 PM
whd507's Avatar
whd507
just be sure to give the site sponsors the first shot....
I'll trade you some longbeds, plenty of them out here.
Old Nov 23, 2004 | 09:24 PM
79pos's Avatar
79pos
Its not just the bed its the cab, the drivers side corner is rusted out a pretty big chunk. The cab roof looks like its been caved in and then filled with bondo. If it was recent I would pop it out and smooth it out but its been collecting water for years and it was up in Montana. In a local paper theres a supercab for sale and a shortbed for sale real cheap. I got to figureing if the supercab/shortbed combo would work that would be easier than cutting the frame. At least that way the frame wouldn't have been cut at all. It seems like the reg. cab longbed frame would fit.
