I have a 94' Ford Ranger Splash, and i'm having a few noises that i can fix.
-I hear a metalic rattle as i go over fast, short bumps like rail-road tracks. It's coming from the front of the truck and i can find the rattle, what is it?
-I'm also hearing my driverside door rattle as if it's getting loose. I've moved the door locking mech. in so it would lock tighter, didn't work, anyone else having this prob? If so, how do i fix it?
Have you checked your front pads to see if the anti-rattle clip is still on the inboard shoes. I see this all the time, people complain of a rattle in the front end. Its just the pads jumping upm and down on the spindle.
im working on an 1987 ranger. the clutch pedal went to the floor and had no pressure. so i replaced the clutch master cyl and the slave cyl and i cant get it to bleed. any suggestions?
Your post should really be done as a new thread. As it is, its buried in someone else's post that is on an entirely different subject. By starting a new thread, your question is more likely to get responses and won't detract from Moto-man's question.
