Aerostar Ford Aerostar
92 Aero - ign switch
Old Nov 18, 2004 | 09:10 AM
vaughnj's Avatar
vaughnj
Can I remove the ign switch on a 92 Aero? If it's the white box under the column with 2 brass torx heads, I think I can. Can the ign switch keep the coil from sending voltage?
Old Nov 18, 2004 | 10:42 AM
vaughnj's Avatar
vaughnj
OK, I replaced the ign switch - no spark
I changed out the ign switch. I noticed a burn on the connector. This seems to be the item that causes dash fires.etc. Anyway, I still have no spark. I have only .9 volts on the starting curcuit. The start/run and run curcuits have 11.8 volts. I can find no more trouble shooting for this circuit. Any ideas?
