clunking underneath
Old Nov 18, 2004 | 08:46 AM
tp's Avatar
tp
clunking underneath
Gents- Don't know if this is right forum because pbm isn't the engine. In 2 or 4 wheel drive I get clunking right under my feet while driving...most noticeable while truck is on bad or off road situation and swaying bck and forth over bumps. I've scooted underneath and front driveshaft does have some movement to it, but isn't some normal at rest? What else could be the pbm? or is the front shaft yolk the pbm? Thanks in advance for any suggetions. Terry ps...truck has 35,000miles on it.
Old Nov 18, 2004 | 03:18 PM
Lashlaroo's Avatar
Lashlaroo
I read a post here a month or two back about the drive shaft slip joint not being lubed. They said the clunking noise stoped after greesing the spline. ????
Old Nov 18, 2004 | 05:24 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Check out the "Tech Folder"
