speedo recalibration
Old Nov 18, 2004 | 04:55 AM
brooks35's Avatar
brooks35
I have a 97 EB 4x4 with the 5.4. I changed to a 315-70-17 tire and want to get the speedo recalibrated. All the computer tuners that are offered only show that they can do this on 99's and above with electronic odometers. Does anyone know how I can get this taken care of on my 97?
Old Nov 18, 2004 | 10:07 AM
buzzard's Avatar
buzzard
Ford makes different "colored" gears that are just inside the housing where the speedo cable enters the tranny. Call your local ford dealership's parts departments and find out which gear you need. You'll need to be able to tell them how much taller the new tires are than stockers.
Old Dec 25, 2004 | 11:58 AM
cobrah's Avatar
cobrah
Smile May wanna try...
Tell ya what, I have the same tire on my Xpy. 4X4 EB w/ a 3" lift (97). I was told to disconnect my NEG. side of the battery for about 30 sec. This would signal the computor to recalibrate things like "trans. shift times", and speed, and other things as well.
The state patrol has a portable radar display they set up at various locations around where I live. I have compaired my speed with there digital radar desplay...(after the neg. batt. thing.) I was dead on the money 35mph/ I went back and tried it again at 47... bullseye again.
After I took the NEG side off for 30sec. I drove down the express way for around 5 mi. then into town, start and stop, then home. Checked it out the next day. All I can say is " I'm happy w/ the results"
Old Dec 25, 2004 | 08:56 PM
austinjorg's Avatar
austinjorg
03/EB/5.4/2WD
While on that subject of the battery, does anyone know what all is "reset" by disconnecting the negative side of the battery? I've heard you are supposed to do this every so often.
What all does is it do??
Thanks and Merry Christmas and Happy New Year
Jorg
Old Dec 25, 2004 | 09:23 PM
AlfredB1979's Avatar
AlfredB1979
Originally Posted by austinjorg
03/EB/5.4/2WD
Jorg
Everything that is powered from the battery.
If you love the radio presets, just pull the fuse to the computer in the underhood relay box. (Brilliant idea = nobody thinks of that!) Isolate one circuit and avoid potential arcing (destroys a computer) and massive monetary outlay in the process.
All factory settings are set back into action. If you are hard on the pedal, the tranny will learn that....it forgets that habit when the ECM fuse is pulled.
rat49f6
Jun 21, 2012 02:38 PM
69ford99
1978 - 1996 Big Bronco
Dec 14, 2006 01:59 PM
Chipster
1997 - 2003 F150
44
Mar 30, 2005 01:10 AM
Deacon Stanley
Nov 9, 2004 10:13 AM
fiend
40
Jan 2, 2003 01:55 PM
