Transmission Leak.
Old Apr 2, 2002 | 10:18 AM
TLynn's Avatar
TLynn
Transmission Leak.
My 1999 2-wheel drive Ranger w/3.0 V-6 auto
has developed some sort of transmission fluid leak. It seems that it is spraying transmission fluid all over the undercarriage and frame of the truck. Seems that a hose is leaking because I don't see any transmission fluid coming straight out of the transmission.
This is the 2nd transmission this truck has had. This transmission has about 40,000 miles on it and the truck has 50,000. The transmission shifts pretty hard also, though not all the time.
Any ideas would be appreciated. Thanks.
Old Apr 2, 2002 | 10:32 AM
Ken00's Avatar
Ken00
Transmission Leak.
It could be from the cooler lines, or a seal. Does it seem to be a spray from someting rotating or from something just squirting it out. What area of the frame, I'll look under my 2000 3.0 SC to see whats there.
Old Apr 2, 2002 | 03:55 PM
TLynn's Avatar
TLynn
Transmission Leak.
The area is all across the frame (total width of truck)between the bed and the transmission so its about a 3x6ft area where the fluid is leaking,it looks like someone sprayed tranny fluid all over down there its even driping from spots.
Old Apr 3, 2002 | 08:24 AM
Ken00's Avatar
Ken00
Transmission Leak.
I looked into your problem and you might find this TSB to be your problem. I would keep an eye on the fluid level until you get this repaired.
00-24-02, Publication Date: NOVEMBER 14, 2000
FORD:1998-2000 RANGER
ISSUE:There may be a vibration at high speeds which may cause the transmission extension housing seal to leak or the transmission extension housing bushing to move out of position or become damaged on some vehicles
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage
Old Apr 3, 2002 | 08:29 AM
TLynn's Avatar
TLynn
Transmission Leak.
Thanks Ken.
Old Apr 3, 2002 | 10:05 AM
wptski's Avatar
wptski
Post Transmission Leak.
