Reassembled
Old Nov 17, 2004 | 07:38 PM
bowez's Avatar
bowez
Reassembled
After replacing head and having a valve stick finally got it to start last night but all is not perfect.
Need to recheck timing I know, but dont think it would cause my issue.
Idles fine, though kinda hard to tell with the rear exhaust disconnected (dropped bolt down exhaust and had to remove to get at it), put it into drive and stalls throwing light. Check codes in On postion (not run) and get I believe 31.
If Disconect EGR would this eliminate this as a cause?
Also anyone have Vacum diagram (after about 3weeks think memory could be off, but think I got them all right). Smog pump/canister is my main concern.
