2.9l v6 oil problem
Old Nov 16, 2004 | 10:03 PM
problemranger's Avatar
problemranger
Unhappy 2.9l v6 oil problem
My 1989 ford ranger with a 2.9l V6 has an oil problem. The oil thins really quick and has a gas smell to it. The truck runs bad after the oil warms up. when I change the oil it runs fine until the oil thins again. The oil pressure will change throughout driving but stays around normal. This is the second motor that has done this.Could it be the a gasket or the piston rings going bad?Any suggestions on what to do? Would it be better to rebuild the old motor or fix this one?
Old Nov 17, 2004 | 01:10 AM
sjwoody's Avatar
sjwoody
2.9's had a problem with heads cracking, but I would have thought most of these problems would have been worked out by now. One of my heads had a hairline crack (I couldn't see it until the machine shop pointed it out). The problem was the casting where the rocker shaft bolts on isn't beefy enough. Anyway...if the oil is thinning and perhaps a little foamy, it's probably antifreeze. Check your overflow bottle or radiator and see if you have a low level. My truck used about a overflow bottle size amount of antifreeze about once a month until I replaced the heads.
Hope this helps.
Old Nov 17, 2004 | 07:34 PM
problemranger
Unhappy not the problem
The radiator doesn't lose any fluid. the oil isn't foamy. The oil smells like gas. and is very thin.
Old Nov 17, 2004 | 07:59 PM
sjwoody's Avatar
sjwoody
uh oh, I've not had this problem on any of my vehicles, but it sounds like you have an injector stuck open, or at least leaking. With your truck shut off, the pressurized fuel system will bleed off through the injector, running into the cylinder, and seeping past the rings into the oil pan. Over time this fuel will accumulate until it's noticable in your oil.
Like I said, I've not actually seen this problem...anyone out there verify my opinion?
If this is what the problem is, try some injector cleaner first...an easy fix if it works.
Old Nov 17, 2004 | 08:33 PM
rangerboy21's Avatar
rangerboy21
I agree with you sjwoody!
You can take an ohms reading on the injectors to see if one has a big difference compared to the other ones. I'm not sure what the ohms specifications should be.
You can also use a long handled screwdriver held up against each injector to see if you hear a clicking sound which would indicate it is working.
Old Nov 17, 2004 | 08:45 PM
Ken00's Avatar
Ken00
Run the truck for a few then shut it down and pull the vacuum line off the fuel pressure regulator and check for gas, common problem. Don't run it with gas in the oil except for test reasons.
parkland
General Diesel Discussion
Mar 31, 2014 06:06 PM
foppyween
Aug 20, 2009 07:21 AM
professor
Jan 21, 2005 08:48 PM
tke_800
Bronco II
21
Mar 19, 2004 06:02 PM
BackwoodsBum
Bronco II
Jul 3, 2001 02:34 PM
