Sponsored by: Real Truck
FORD Gear Differential Additive!?
Old Nov 16, 2004 | 07:56 PM
Bigtruckdriva's Avatar
Bigtruckdriva
Wondering if anybody knows what the heck the purpose of that additive is for that you add to your differential. I know it keeps the clutches lubed so they slide smoother but what if I don't put this additive in will it make my posi loud? or just make the clutches grab better? Any info is greatly appreciated as I am going to put 4.88 in my truck in a couple days, and want to have limited slip but still want both tires to grab well in loose terrain.
THanks
Old Nov 16, 2004 | 08:12 PM
79 f100's Avatar
79 f100
Friction modifier is used to keep the clutches from chattering and ruining themselves. If your rear diff. is anything bigger than an 8.8 then you should use two bottles of modifier.
Old Nov 16, 2004 | 09:47 PM
Musicman250's Avatar
Musicman250
I recently used Quaker State fully synth 75-140W and their tech support told me it already has friction mod in it(although there is no mention on the bottle). So no need to add any.
I found this out AFTER i had put in 1/2 a bottle of ford friction modifyer, but no problems so far.
Old Nov 17, 2004 | 05:48 AM
philips's Avatar
philips
At 5K I replaced the fluid in my rear axle with Mobil 1 synthetic 75w-140. I did not add any friction modifyer. I ran my Ranger like this for 9 years 140K with no problems. In fact, I had good posi. Philip.
Old Nov 17, 2004 | 05:57 AM
DS02F250's Avatar
DS02F250
Ianlavin is correct. Some gear oils already have the friction additive in them. Others don't, so you'd have to buy the friction additive separately and put it in with the new gear oil when you swap gears to the 4.88's. And always use the recommended weight gear oil (Ex: 75w-140). I used Royal Purple and everything's fine on mine (76K miles).
Daryl
DSMMH
Jul 1, 2015 08:54 AM
ChefJeff1
Mar 2, 2015 07:50 PM
msgtg
General Diesel Discussion
13
Jan 14, 2011 09:14 PM
76F250HighBoy
1997 - 2003 F150
Apr 14, 2007 09:03 AM
bdgstaylor
Feb 8, 2005 02:53 PM
