Offroad & 4x4
Divorced transfer case???????????
Old Nov 16, 2004 | 06:09 PM
62uni4x4's Avatar
62uni4x4
I was wondering if someone might know of an aftermarket torque mount
for a divorced in a highboy????
My torque bar iw wasted, I need to come up with something a little stronger
Thanks
John
Old Nov 17, 2004 | 01:33 PM
proeliator's Avatar
proeliator
I don't believe that there are aftermarket ones, but they are a dime a dozen in a boneyard. You shouldn't NEED a stronger one, if you are seeing that much twisting at that point you have some serious probems with your motor mounts and need to look them over carefully.
Old Nov 22, 2004 | 08:06 PM
Randyb12's Avatar
Randyb12
A Divorced tc is seprerated from the engine/trans by a short driveshaft. The engine could be rotating 90 degrees and the tc would not move.
What tc are you useing?
Old Nov 22, 2004 | 08:09 PM
proeliator's Avatar
proeliator
Really!?
Good catch though, for some reason I would have sworn he said he needed the mount for his transmission...I wonder if he edited his post...especially since his question doesn't make much sense now.
Old Nov 22, 2004 | 08:18 PM
Randyb12's Avatar
Randyb12
Pro, No it doesn't. That is why I asked about the type of tc he is useing.
John, What do you mean by a torque bar?
Old Nov 22, 2004 | 08:57 PM
mustange70's Avatar
mustange70
I think he means the one on the back of the transfercase that goes from the bottom of the t-case up to the frame. If this is what he twisted there are probably more serious problems like broken motor/tranny mounts.
Old Nov 23, 2004 | 11:26 AM
Toyman's Avatar
Toyman
What kind of horse power are you running? I had a problem a few years back with to much hp (850) and not a strong enough frame. Even after boxing the frame I could not use a rubber mount. Frame flex is hard (and expensive) on everything.
Good luck
Toyman
chukar
Nov 27, 2016 07:29 PM
TheTowingCowboy
Jan 15, 2012 09:51 PM
SilverHighboy
Jul 12, 2010 10:39 AM
Hazmat 67
Jun 2, 2010 08:18 PM
Craigwell
Feb 2, 2006 01:08 AM
