bii injectors
Old Nov 16, 2004 | 05:34 PM
ohioredneck's Avatar
ohioredneck
Lightbulb bii injectors
hello all i have an 88bii 4x4 2.9 5 speed i was wondering what size are my injectior?? would the injectors from a 91eagle talon tsi awd be an up grade? thanks all
Old Nov 16, 2004 | 10:56 PM
EPNCSU2006's Avatar
EPNCSU2006
I wouldn't mess with the injectors. Unless your engine is highly modified and requires more fuel than the stock injectors can supply, don't bother going any larger - it won't gain you anything. If the injectors are not working properly or are clogged, some newer injectors would likely help get the thing back up to speed, however, make sure they have the same flow rating as what was stock. The newer design injectors supposedly have a better spray pattern, but I don't think it is very noticable.
Old Nov 16, 2004 | 10:59 PM
Monty06's Avatar
Monty06
check out summitracing.com for b2 injectors upgrades usaully they are 17lbs stock i have 19lbs does better but that's with some mods to the engine.
