cooling system pressure
Old Nov 16, 2004 | 02:33 PM
someday's Avatar
someday
what should i check if the cooling system doesnt hold any pressure? it is an 89 e250 5.0 and there doesnt appear to be any leaks and i just changed the thermostat and the temp sending unit because the temp gauge says it is overheating
Old Nov 16, 2004 | 05:06 PM
Ultramagdan's Avatar
Ultramagdan
The cap would be the first thing I'd check. Are you sure it's not holding pressure?
Old Nov 16, 2004 | 05:25 PM
someday's Avatar
someday
that is what i am going to try next. when i squeeze the upper hose it goes flat and when i take the cap off there is no air coming out or coolant
Old Nov 16, 2004 | 09:33 PM
Ultramagdan
Blown headgasket may be the next culprit.
Old Nov 17, 2004 | 05:30 PM
someday's Avatar
someday
here is a better summary of what is happening: the gauge when driving is hovering at the end of the normal just before hot, the truck still runs fine, the exhaust is not smoking, the temperture of the coolant in the radiator is about 195 F, new 195 F thermostat, radiator cap, temperature sending unit, and no diagnostic codes. should i change the coolant temperture sensor or do i have another bad temp sending unit? are there any checks i can do on the temp sending unit?
Old Nov 17, 2004 | 07:27 PM
Ultramagdan
Do you have bubbles in the coolant? I tend to doubt it's the sensor or the sending unit. Your system should pressurize.
Old Nov 27, 2004 | 01:51 AM
TNTsF-250's Avatar
TNTsF-250
Have you tryed using a rad. pressure tester? also is your gauge reading properly?
