'54 V-8 compression test results
It's a completely stock engine, and the shop manual states the compression for a new engine is 130 psi. The readings on my engine are 100 to 107, but I may have made a mistake conducting the test.
I warmed up the engine, as the spec sheet in the manual implied. I also removed all the plugs. One thing I DIDN'T do though was open up the throttle all the way while taking the readings. I've read on the internet that this allows the cylinder to "gulp" more air. Would my readings be understated because of this? Or does it not really have that much impact on the results?
Also, the spec sheet says that the 130 psi is as taken at sea level...I'm about 1000 feet above sea level. Not important?
Those 2 things aside, how would you interperet 100-107psi on an engine that read 130 new? I have a little smoke (sometimes) when I start up, but it always goes away after 10 minutes of driving, and doesn't come back for the rest of the day. I've been told it's probably valve guides and not to worry. Would that effect my test results? Thanks - JR
EDIT: JR, i forgot to mention, but on factory book compression specifications, they mean with a teaspoon of 5weight oil placed into each cylinder before taking a reading, that boost the reading, as when you are driving a cylinder has a tiny amount of oil and gasoline on the compression stroke making it that result of 130, but a dry check JR would be about 100 or less as i said. The reading is aquired with a teaspoon of oil per cylinder with throttle closed, but if your engine isn't shaking and at that 100 to 107, drive and enjoy JR, sounds like you have a great old engine there.....Janet
