Bronco II Ford Bronco II
Up Grades!!
Old Nov 15, 2004 | 09:05 PM
ranger982's Avatar
ranger982
Up Grades!!
Just taking a quick poll what are some of the best upgrades you have done or want to do to your B2 I converted to manual hubs put a duraspark system in upgraded the carb and bigger tires bumperguard and lots of lights!!! i want to get a small lift. what do you guys think??
Old Nov 16, 2004 | 05:37 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Go for it,and while your at it up grrade your alt. and battery to keep up with all the lights.
Old Nov 16, 2004 | 07:39 PM
ranger982's Avatar
ranger982
what kind of alt. do you recomend???
Old Nov 16, 2004 | 08:42 PM
GrayRanger4x4
Sorry I was just joking I should have said it..But I would get the bigest battery{cold cranknig amps}that you can and make sure all your cables are good and clean.
Old Nov 16, 2004 | 08:47 PM
ranger982's Avatar
ranger982
i probly should cause with all lights on blower fan going, at idle the lights lightly dimi do have an upgraded battery
Old Nov 17, 2004 | 12:54 PM
CherryColaholic's Avatar
CherryColaholic
What kind of lights and how many? I have 9 KC daylighters... 100 watts, 100,000 candlepower each. My voltmeter goes waaaay down when i turn them all on at once. I usually only use 5-7 at a time. You should post some pics in your gallery.
Old Nov 18, 2004 | 11:02 PM
admiralturbo's Avatar
admiralturbo
how big of tires are you running or want are you fixing to go to?the height of lift affects the tires you can run..
A good inexpensive small lift is 2''.just coils.liftblocks an an alighnment.will clear 31s no problem,mayyybe 32s
Old Nov 19, 2004 | 05:38 PM
RomerB2's Avatar
RomerB2
I have 31's on mine, with no lift (no money), and I have no problem with rubbing or anything. If you're just wanting a small lift, just swap out springs from a 91-94 Explorer. If you're wanting to go bigger than that, get an extention for the back spring, or you can get a lowering kit for leaf springs off of a chevy, and it will work too. You didn't say what year you had but if it's 88-90 you can upgrade the TB from an 86-87 ranger or bii, and get more from that. Today I put in MSD ignition, and I'm liking it so far, I'm getting 8.8mm wires next week, can't wait.
Old Nov 21, 2004 | 05:17 PM
ranger982's Avatar
ranger982
i have 31 inch tires and they barley clear the fenders just sitting, when articulating they rub you say rear spings from a 91 to 94 explorer will llift it up? cool.....are there any good vehicles to get a high amp alt? prefribly a one wire that would require little mod's it is a 84 b2
Old Nov 21, 2004 | 07:14 PM
DMANGANNON's Avatar
DMANGANNON
I Have A Bii
I Have 30' Tires On My '88 Bronco Ii...i Am Looking For A High Watt Amp As Well!!! Did You Say You Can Lift It With Springs From A '93 Explorer? I Just Got Myne Do You Guys Have Any Suggestions? There Is A 2.9l Engine In It With Fuel Injection!!!
Old Nov 21, 2004 | 09:17 PM
plilikoi's Avatar
plilikoi
The best upgrade for getting up grades is more torque, a more powerful engine.
Old Nov 22, 2004 | 09:28 AM
GrayRanger4x4
Question
WHY??
Old Nov 22, 2004 | 10:23 AM
plilikoi's Avatar
plilikoi
Originally Posted by GrayRanger4x4
WHY??
Is there any other way to get "up grades" better? ;-)
Old Nov 22, 2004 | 10:58 AM
GrayRanger4x4
Heres one.. Lower gears.The 2.9 is down on HP but the litte 6 has got low end torque already.I like the light weight of the v6 and low end torque for the tail.
Bigger engine means bigger tranny,t-case,f/r axles. Sounds like a lot of work to me{I'm lazy}.So if you went a v8 in a 4x4 buy one that comes with a v8.JMHO
Old Nov 22, 2004 | 12:54 PM
plilikoi's Avatar
plilikoi
That's a valid point. I wonder whether it's possible to adjust the transfer case so that the entire low range becomes lower? As it is there's considerable overlap between low and high ranges and I don't think I've ever gone above fourth gear in low. I just stop and switch to high range.
I've gone both up and down hills where I wished that low range first was lower.
