Replace 04 SCrew F150 Seats
Old Nov 15, 2004 | 07:51 PM
Shifter125's Avatar
Shifter125
Lightbulb Replace 04 SCrew F150 Seats
I would like to replace my '04 FX4 SCrew 150's leather / electric seats with a better set...I like the '03 F350's seats, but didn't know if I would run into compatibility issues. The '03 F350 has better lateral support, heated etc vs my '04.
Any experience out there with this?
Old Nov 15, 2004 | 08:11 PM
Joho1212's Avatar
Joho1212
If you decide to switch them out id be interested in buying your old seats from you! Contact me via email. jonathanthoman@aol.com
Thanks
Old Nov 15, 2004 | 11:46 PM
blitzen25bm's Avatar
blitzen25bm
dont know how you would hook up the heated seats easily but i think the 350's seats would be too wide.
Old Nov 16, 2004 | 07:57 PM
Shifter125's Avatar
Shifter125
Thanks for the replies, much appreciated.
Old Nov 16, 2004 | 08:10 PM
Harrski's Avatar
Harrski
Not sure if it can be done, but here are some things to check out before you do it. Check the bolt pattern of the seats to see if they match. Also if you want the new one's to be electric check to see if the wiring harnesses match, if not you will have to cut off the harness connectors and soder the wires together. Last if you want the heated seats and you don't have them now you will have to install the switches and relays to make it work.
