This would be cool
Old Nov 15, 2004 | 06:19 PM
warren1994's Avatar
warren1994
This would be cool
A '79 full size Bronco with 460 and a C6 tranny. Swap in a diesel? How hard would it be? I'm thinking a 7.3 n/turbo with 3" pipes.
Old Nov 15, 2004 | 07:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
New front springs, diesel is 1100 pounds
New radiator, diesel needs way bigger
New transmission, gas version will not work
Make motor mounts
Make transmission mounts
New rear axle Dana 60 or 70 or Sterling 10.25" to stand the torque.
New transfer case probably, BW 1345 is minimum.
The Dana 44 IFS will not take a diesel very well, recommend a Dana 60 straight axle front end.
New fuel system, diesels have return lines.
Dual batteries so you can get it started.
New drive shafts to stand the torque.
Regear the axles to 3.55's or 4.10's so you can drive over 45 MPH.
And worry about the frame folding up when you get it in a bind.
Plus the motor.
Other than that it will be a piece of cake.
Old Nov 15, 2004 | 08:31 PM
captjohn's Avatar
captjohn
Dont forget the wiring.
Old Nov 15, 2004 | 09:09 PM
rancherman84's Avatar
rancherman84
diesel in bronco
back in collecge one of my instructors put a 6.5 turbo in an original style bronco,did a nice job just to bad he wasted his time with 6.5
Old Nov 16, 2004 | 07:29 PM
Dave Sponaugle
For what it is worth the wiring would simple compared to the rest of the job.
The IDI really does not need much in the way of wiring, glow plugs with the new style controller or manual are easy to wire.
Starter solenoid on the firewall jumps to solenoid on the starter.
Oil light sender hooks to oil light.
Oil guage sender hooks to oil guage.
Temp sender hooks to temp guage.
Ignition wire goes to the IP and the temp switch for the fast idle and timing advance. Wiring is now done.
But if you were going to do a good job on the rest of the mechanical work....that is another story. If you were doing it so it started and moved...well I guess you could cobble it in without that much trouble.
