Sponsored by: Real Truck
Smart guys, Help!
Old Nov 15, 2004 | 06:14 PM
SDown1's Avatar
SDown1
Exclamation Smart guys, Help!
So, I locked my keys in my 2000 superduty (supercab) and don't have another set. Is there any way to break into the truck without damaging anything...or am I just going to have to shell out some cash to the locksmith/Ford Motor Companies?
Old Nov 15, 2004 | 06:24 PM
wezol5484's Avatar
wezol5484
Okay this is what you can try...I did this when I was out in the middle of our land out inthe middle of no where.
Assuming you have power locks, get a flathead screwdriver and another helping hand. Unscrew your antenna (or a coat hanger, but make undo it to extend it full length). Insert the flat head screw driver into the top of the door seem, and pry out VERY CAREFULLY, have your helping hand hold it like that. Then insert the antenna or coat hanger down and hit the power lock button, and wallah, you got it. When I did this it didnt put a single mark on the door, but just be carfull. It only has to come out enough to fit a coat hanger down into. Hope that helps.
F2504x4's Avatar
F2504x4
take your vin# and Id to the dealer and have them cut you a key.....or call triple AAA
Old Nov 15, 2004 | 11:25 PM
justinthurn's Avatar
justinthurn
and then.....when you get in get a spare cut and wire it to the frame (well hidden of corse) then you never have to worry again!
Old Nov 20, 2004 | 04:10 AM
SuperDutyJ4500's Avatar
SuperDutyJ4500
Smile
good idea with the screwdriver thing..but in the future..always create a spare set..and that way you wont have to worry about using that technique..just my 02 cents...
