home made AIC problem
Old Nov 15, 2004 | 02:32 PM
shendoa's Avatar
shendoa
I made a home made aic with a 10 turn 2k pot, when i turn the switch on the aic the pot is in the lowest setting. all the way to counterclockwise, the engin raises to 19 hundred rpm, if i turn the pot to right 3/4 turn it goes to 24 hundred rpm, this is a 10 turn pot, what should i put in line to drop rpm and get more turns? some kind of dioid / resistor / ???? I am not a electriction so I have no idea, it works good, just wish I could lower the rpm so i can get at least 2 to 3 turns or more on the pot without going to 3500 rpm with 3 turns??? If i turn pot to right rpm goes up to left rpm goes down just not low enough.
Old Nov 15, 2004 | 02:59 PM
shendoa's Avatar
shendoa
the pot is either to big or too small, i need a resistor in line on tps but don't know what value???any ideas??
Old Nov 15, 2004 | 04:18 PM
shendoa's Avatar
shendoa
ok I fixed it = put a 1k resistor in line, now works good.
countrydriven
Dec 23, 2016 02:39 PM
K.Ray
Mar 20, 2014 09:49 AM
SuperMike
Apr 7, 2013 11:13 AM
tjbeggs
49
Mar 11, 2007 07:17 AM
Big_Al59
Nov 20, 2005 09:03 PM
