1989 f150 idle problems
Old Nov 15, 2004 | 10:50 AM
johnsar's Avatar
johnsar
I have a 1989 f150 300 4x4. removed and replaced motor and now i can not get idle lower than 4000 rpm. I also need the correct vacuum assembly order. Thanks to anyone who can help with this.
Old Nov 15, 2004 | 01:25 PM
90f150moneypit's Avatar
90f150moneypit
Sorry can't help with the vacuum order, but check for a vacuum leak by spraying carb cleaner all over the intake system. 4K RPM (verified with tach?)....can't really be anything else to cause that high an idle. Well, maybe a TPS. But do the spray test first then test the TPS.
Be sure to spray around ALL mating surfaces (EGR/TB/both intakes etc) without spraying inside TB.
Old Nov 15, 2004 | 02:12 PM
johnsar's Avatar
johnsar
Thank you very much, i'll give it a try
Old Nov 21, 2004 | 03:06 PM
ChittyChittyBang's Avatar
ChittyChittyBang
Vacuum Order?
Any Luck finding the vacuum order?
william7
Apr 30, 2016 04:24 PM
roofcam
Aug 14, 2009 01:05 AM
gcancino2003
Jan 19, 2008 06:12 PM
acwhite03
Aug 3, 2003 12:49 PM
garyda
Computer Chips & Tuners
Feb 19, 2002 10:59 PM
