Sponsored by: Innova
Factory CD Player Question??
Old Nov 15, 2004 | 10:13 AM
truszip's Avatar
truszip
I was talking to the local dealer the other day and he tells me that some of the older (97 and below) factory CD players - are unable to play home made CD'S! Is this true?? Any body have any experience with this?? Thanks
Old Nov 15, 2004 | 10:43 AM
maticuno's Avatar
maticuno
If you make the homemade CD as just a normal CD, it will play. I don't think CD-RW type discs will work. Standard CD-R's should work, as long as when you burn the disc, you make sure you check the option of having the burner "close" the disc. And just in case I'm wrong, an upgrade to an aftermarket CD player would benefit you.
