Chip Access
Old Nov 15, 2004 | 10:09 AM
y2kexc's Avatar
y2kexc
Chip Access
Can anyone tell me how to get the computer module box out of a 2000 Exc.
I've taken the plastic retainer box off and don't know how to get the plug off to gain access to the metal box. Is there a interlock or some kind of latch that needs to be released ???? Also when I chance the chip is it advisable to disconnect the power source (battery) before I perform this procedure ????
Old Nov 15, 2004 | 01:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
The electrical connector should have a bolt on it. Remove that bolt and the PCM should slide out of retainer.
You should ALWAYS disconnect the battery when working on anything electrical.
Old Nov 15, 2004 | 01:23 PM
y2kexc's Avatar
y2kexc
[QUOTE=Monsta]The electrical connector should have a bolt on it. Remove that bolt and the PCM should slide out of retainer.
Thanks for the reply...Is the bolt on the top or the bottom. Or do I just need to feel for it ? Problem is access is very limited, but I'll search around and see if I can locate.....
Old Nov 17, 2004 | 06:55 AM
FTE Ken's Avatar
FTE Ken
Open the hood. The computer box sticks through the firewall down low where the battery is. There is a 10mm bolt attaching the wiring harness to it.
Old Nov 17, 2004 | 05:56 PM
y2kexc's Avatar
y2kexc
Thanks Ken, will investage
Old Nov 21, 2004 | 09:44 PM
FC X's Avatar
FC X
Where is the Chip in a 2001 X?
Bought a used 2001 X Diesel and I want to know if it has been chipped. What is the easiest way to tell?
Thanks,
FC X
Old Nov 23, 2004 | 11:10 AM
FTE Ken's Avatar
FTE Ken
Look at the computer box. If there is a module sticking out of the computer service port, its chipped. Another way to tell if its been chipped (or tuned with a handheld) is to read codes and look for a P0603 code.
