F250 Limited-Slip Diff Chatter
Old Nov 14, 2004 | 08:36 PM
2CZee's Avatar
2CZee
My 95 F250 (55,000 actual miles) 410 Limited-Slip Diff has a severe chatter when making turns. It even vibrates the entire truck.
A reliable shop inspected, found no apparent internal problem. Changed oil to Amsoil w/ Friction Modifier.
Drove slowly in tight turns, back and forth, but it still does the same thing.
What's happening? What's the fix? If left alone will it eventually wreck the rear-end?
Thanks...
Old Nov 15, 2004 | 12:36 AM
Blurry94's Avatar
Blurry94
With those symptoms, it seems to me, that you still don't have enough friction modifier. I know guys runnin 8.8's with LSD's that have that problem add more friction modifier and that usually cures the problem.
Old Nov 15, 2004 | 12:41 AM
andym's Avatar
andym
Friction modifier actually reduces the friction created by the LS clutches, so adding more modifier will actually reduce the amount of 'grab' te clutches offer - which means less chattering.
Old Nov 15, 2004 | 01:55 PM
fordberg's Avatar
fordberg
Hi. This is the text from a previous post of mine. Do you think what I am hearing is the LS rear end? I will have to try turning the other way to see if the clunk changes sides.
When I drive, when I back up, mostly when I turn fairly sharp and give it just a little gas to get her moving I get this cluck that resonates thru the entire vehicle. It's not loud just feels like something moves. Feels like the lug nuts are loose on one wheel. Well, anyway I have isolated it to the rear drivers wheel. I have had this noise since I got the truck last year. I have taken the wheel off and the brakes are OK. I didn't try to pry on the axle. Do we think this is an axle bearing or something in the rear-end? I have had the rear drive line off and the rear end back-lash is good.
95 F-250 4x4 E4od
03-F150
1997 - 2003 F150
May 1, 2015 11:32 PM
kabcpapc
May 28, 2014 12:28 AM
Bronc1
2009 - 2014 F150
20
Apr 27, 2014 07:47 AM
bryced15
6.7L Power Stroke Diesel
32
Mar 20, 2014 01:22 PM
Nick2005f250
Jan 19, 2014 07:06 PM
