Instrument Cluster Wiring
Old Nov 14, 2004 | 05:16 PM
Chris Ward's Avatar
Chris Ward
Arrow Instrument Cluster Wiring
I have a March 1983 F150 Supercab 6 cylinder Desert Tan/Beige.
I got a 1980 cluster on ebay. Digital clock, and woodgrain bezel and trim.
The cluster did not work when I plugged it in. No tach. No turn even in the wrong places. I put the tach in my old cluster for decoration. I don't have the pc plastic for a tach. Mine is red and starts with F1 not F3. F0 on the non working one I purchased. I got a spray can of Flourescent red/orange at Home Depot. Sprayed some in the cap and then used it and a model brush to paint my needles. Turned out great. I put in the clock for decoration too... I need some info. I would like to know where to connect the four clock wires. Black, White, Green, and Blue.
I would like the pinouts for the cluster connector. Haynes makes no sense to me. My wires are all different colors from the Haynes.
I would like pin 1 through 18 written down 1 through 18. The layout in Haynes makes no sense. They are not numbered.
I took the 1980 bezel and peeled off turn and fasten belts and brake and glued them where they belong in my truck. I took the little blue caps off so dash light are viewable in the dark. Those needles sure do glow nice now!
Since I don't know which wire in my connector is coil can I run a new one to back of tach.? Then just hot and ground needed, right?
Rogue_Wulff
'80-'86 HOWTO's
19
Jan 21, 2025 10:13 PM
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
Hardtruckisthebest
Feb 26, 2014 02:32 PM
Rogue_Wulff
16
Mar 19, 2012 08:38 AM
Nightrain
Dec 24, 2004 10:01 AM
