Checking Transmission Fluid
Old Nov 14, 2004 | 04:45 PM
Tank1482's Avatar
Tank1482
I Have a 1990 F-250 and i need to know where is my transmission fluid dipstick?
Tank
Old Nov 14, 2004 | 05:14 PM
Beast12's Avatar
Beast12
It is on the passenger's side of the engine near the back. It probably has a white or black handle on it.
To check your fluid park on a flat level surface. Get the transmission up to operating temperature. PLace the tranny in park then shift to reverse (hold in reverse for 3-5 seconds), then shift to neutral (hold it there for 3-5 seconds) then shift to drive and hold it there for 3-5 seconds. Then shift back to park but stopping in all the gears for 3-5 seconds again. Then check your level. Add fluid into the dipstick tube if required.
-Matt
Old Nov 20, 2004 | 02:05 PM
Tank1482's Avatar
Tank1482
Thanks! Man I would of never Seen it if you did not tell me where it was at lol.
Tank
Old Nov 20, 2004 | 02:08 PM
Beast12's Avatar
Beast12
No problem! And Welcome to FTE! Look, you already learned something!
-Matt
Old Nov 20, 2004 | 02:29 PM
Tank1482's Avatar
Tank1482
Yep!
Tank
