Brake controller woes
Old Nov 14, 2004 | 03:42 PM
walnutcreek's Avatar
walnutcreek
Question Brake controller woes
I hooked to the horse trailer that we just bought and the controller showed the connection, but the LED stayed yellow and the level and power adjustments made no difference. It worked on the last horse trailer and works on my gooseneck lowboy just fine. What gives?
TIA gang
Old Nov 14, 2004 | 04:40 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Check the wires on the new trailer's plug, maybe someone wired it different, also check that the ground is good.
Old Nov 14, 2004 | 05:42 PM
04superduty's Avatar
04superduty
what brake controller do you have?? you might be able to find a trouble shooting section online for your brake controller or someone here might know.
check the plug to see that the connector things arnt bent. cant think what they are called.
Old Nov 14, 2004 | 09:32 PM
walnutcreek
Smile Brake controller woes
I'll check the ground wire first and then the trailers wiring. The controller isn't the problem as I hooked to the lowboy and towed it to check it out...everything functions normally.
Maybe after it warms up tomorrow and the morning chores are done.
