Sponsored by: Auxito
99 Remote door locks
Old Nov 14, 2004 | 12:57 PM
Cunningham's Avatar
Cunningham
Thumbs up 99 Remote door locks
I just bought a 99 Ford XLT with power door locks. The remote key fobs where gone, did all 99 XLT trucks with power locks have the remote feature.
Old Nov 14, 2004 | 03:05 PM
newt sweet's Avatar
newt sweet
i have a 99' also, no key fobs, no remote module to work it. just buttons on the inside of door and my trusty key.
Old Nov 14, 2004 | 09:40 PM
jjlogue3's Avatar
jjlogue3
I have a 99 f-150 XLT and have the fobs but I am not sure if all XLT's came with it but I am sure your local Ford dealer could answer that question for you.
Jeremy
Old Nov 14, 2004 | 09:46 PM
Cunningham's Avatar
Cunningham
Thanks! The ownwers manual talks like all 99 XLT was equipped with remote but I wasnt sure. I'll call the dealer tomorrow befor I buy fobs.
Old Nov 14, 2004 | 11:28 PM
Racerguy's Avatar
Racerguy
Cycle the key in the ignition from off to run 8 times in 10 seconds. If the door locks cycle after the 8 turns of the key then you have remote keyless entry.
Old Nov 18, 2004 | 11:19 PM
fatherheart3's Avatar
fatherheart3
Lightbulb
I have a 99 lariet f-350 dually that When i try to program new remotes,i did not have one,it will only program one.Is there a memory that after four are programmed it will not do more..If so is there a way to erase it so I can have at least two remotes...Thanks Wendell
Old Nov 18, 2004 | 11:36 PM
Racerguy's Avatar
Racerguy
The owner's manual says that up to 4 may be programmed.
I'm not positive but I believe that your dealer can reset this with their WDS or NGS scan tool. If you take it in make sure you take all your remotes along.
Old Nov 20, 2004 | 09:02 AM
Thudpucker's Avatar
Thudpucker
Racerguy you Da man! Right now there's some guy selling the Remote Keyless for our F series. He says they will work with my 97 but I never knew how to check for the modules. Thanks for the "8 Key flips" tip.
