Shift lever repair E40D
Old Nov 14, 2004 | 10:12 AM
Ringo Fonebone's Avatar
Ringo Fonebone
Can any one give me some advice on how to remove the shift lever from the case in an E40d.. i have the pan off, the nut off the end of the shifter, inside.
I also have the position sensor removed. But I want to take the shift lever off the case for some welding repair, so I don't fry the seal welding it in place.
How do I get the lever out? There seems to be a big smooth, round,sleeve holding it in from the inside, that does not appear to unbolt from the lever.
Anyone know how?
RF
Old Nov 14, 2004 | 10:59 AM
Racerguy's Avatar
Racerguy
If you look on the case near where the pan gasket goes you'll see a roll pin holding the manual lever shaft in. You need to remove that pin. Good luck
Ford has a special puller for removing it but some people have got lucky just screwing a 1/16" drill bit into it and pulling it out with that.
Old Nov 15, 2004 | 12:43 AM
Ringo Fonebone
Thanks a LOT Raceguy. I see it, just have to figure out the best way to get it out.
You've been a great help. Thanks again!!
TheKirbyMan
Dec 15, 2011 09:27 PM
66_in_ky
May 6, 2010 09:25 PM
csangster
Feb 9, 2010 05:28 PM
rhilsbos
1983 - 2012 Ranger & B-Series
Feb 13, 2004 07:30 AM
Don Beale
May 7, 2001 07:57 PM
