How durable is the 4.0
Old Nov 14, 2004 | 10:06 AM
grease monkey's Avatar
grease monkey
I wanted to know how durable is the 4.0 ranger motors and the reliability.
Is the 4.0 better than the 3.0 or the 4cyl.
Old Nov 14, 2004 | 10:39 AM
Rocky J's Avatar
Rocky J
138K miles on mine, I've done absolutely nothing to the motor except oil changes at 5K intervals. I put new plugs in it a couple years back and I've changed the coolant a few times (every couple years). The truck has eaten a couple batteries in the last five years as well.
Yeah, the 4.0 is a POS.
Old Nov 14, 2004 | 11:00 AM
98xlt4x4's Avatar
98xlt4x4
I'm at 102k miles on my 98 with the 4.0L. Been very good to me, changed oil every 3k, coolant an regular intervals, fuel/air filters frequently. Did spark plugs a while back and put a new clutch in. Been very reliable, always starts right away, has plenty of power empty or pulling... Check out the thread "miles on your ranger" for a little more...
Old Nov 15, 2004 | 07:01 AM
PSKSAM2's Avatar
PSKSAM2
I bought mine with 103k on it and it runs like a champ at 116k now.
-Jim
Old Nov 15, 2004 | 07:55 AM
bcjim's Avatar
bcjim
110K and never a problem.
Old Nov 15, 2004 | 10:26 AM
AG4.0's Avatar
AG4.0
123k, runs good, starting to have trouble idling at cold start, engine fires up good but then bogs down and dies, usually does this 2 times, and then runs like a champ. Probably the IAC or something simple.
Old Nov 15, 2004 | 11:37 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
178,300 miles on my 94 4.0 and I put all but 2.7 of them on the clock. It starts and runs as good as it did the day I drove it off the lot. No oil consumption between oil/filter changes (3000-3500 miles). Items replaced due to outright failure were IAC and temp sending unit (gauge). Hoses, belt, filters, spark plugs, etc I regard as wear items and are omitted.
The highest I've seen so far on a 4.0 is around 325,000 miles. That claim is made by a guy over in the Explorer forum.
Old Nov 15, 2004 | 03:52 PM
hifiwasabi's Avatar
hifiwasabi
My 1999 Ranger has the 4.0 with 117 500 km on it (about 70 000 miles) and the only thing that comes to mind as problematic is the thermostat which I changed two days ago and took the whole of an hour to do. Regular maintenance includes oil changes at 5000 km and every time it amazes me how well these engine run. I should really change the spark plugs, fuel filter, blow out the air filter and flush the transmission fluid, but nonetheless, the truck drives like a Lincoln and has put many a half ton GM in its place.
Sean
Old Nov 16, 2004 | 06:51 AM
dwildmanj's Avatar
dwildmanj
I have a friend that had a 97 Aerostar with the 4.0 in it, and he put 250,000+ miles on it and just recently traded it off for a new car. The only thing wrong with the vehicle was the alternator was going out and he had just started having some trouble with the transmission. I would say that this would say alot about the 4.0, considering most things that were done to it were routine maintenance.
I drove it, and all I could say was "I WANT IT" after I drove it.
Old Nov 16, 2004 | 09:03 AM
johare's Avatar
johare
My '99 has 98,500 miles on it and the only expense outside of 1 battery (battery did not die but I use my truck for camping and fishing and I put a new one in after 5 years just so i wouldn't get stranded in the wilds with no one around - kept the old battery as a spare!) and regular oil changes has been an oxygen sensor. The engine runs strong, has plenty of power and pick-up and I get 20 mpg highway and 16 mpg in town. Couldn't be happier!
Old Nov 16, 2004 | 09:37 AM
LK's Avatar
LK
Which 4.0 are you wondering about, the older pushrod version or the newer SOHC version? In my experience, the older version was extremely reliable - but the newer SOHC version has had some issues.
LK
Old Nov 16, 2004 | 01:16 PM
Thumper47's Avatar
Thumper47
LK
Ya just HAD to go and bust my bubble, didn't ya?!!!!
Just when I was startin' to feel pretty good about my '02 4.0L SOHC....
Oh well..... time will tell......
Thumper47
Old Nov 16, 2004 | 01:46 PM
grease monkey
I have a 97 Ranger with th 4.0 I dont know if it is a push rod or sohc motor.
Old Nov 16, 2004 | 06:35 PM
CowboyBilly9Mile
It's OHV (pushrod).
Old Nov 16, 2004 | 07:03 PM
chich's Avatar
chich
Talking great engine
189000K on my 95 XLT and apart from regular (irregular?!?) things like oil changes filtres and replacing the plugs - OK, I gotta ask. who designed that part of these trucks. little tiny men with long skinny fingers ?!?
Fortunately I put in Platinum plugs last time and should be good to go for a while. Like someone else said, you only have to do the wires and plugs once every great while so don't put in cheap stuff!
anyway, mine runs like a top and I have not exactly been kind to it. I lived up in Dease Lake for four years and the winters are the -40 variety and to get out was five-six hours on gravel/sealcoat roads. can't complain about the 4.0 or the truck itself. In fact my next vehicle will be another ranger if and when this one gives up the ghost.
Just wish the plugs and wires were easier to get at.
