Manual trans id trouble
Old Nov 14, 2004 | 08:37 AM
SAV's Avatar
SAV
Question Manual trans id trouble
Good morning to all,
Can anyone out there help me id this trans?It is a four speed fully synchroed,shift forks(2) on the drivers side of the case,all cast iron,made by ford,no bolt holes on the tailshaft,and the id tag says RAT BV
012147
When compared to the dimensions of a srod, it has the same input shaft length,same bellhousing bolt patten,and the tailshaft is about 2+ inches longer than the srods'.Want to put it in 80 f150,302,2wd.If I get another drive shaft,or shorten the existing one I think it should work.Any response would be great.Thank you. Spence
