Sponsored by: Real Truck
Post your leveled F250
Old Nov 13, 2004 | 09:51 PM
quadsand's Avatar
quadsand
I would love to see your leveled SD F250. I'm looking to level my truck (2004 CC SD F250) as well and would like to see what the outcome will be. Please post the brand of level kit, tire size, shocks, block size, and wether or not you are happy with it. Thanks!
Old Nov 13, 2004 | 10:09 PM
DS02F250's Avatar
DS02F250
Me too. I am interested in the same information (but for my '02 F-250 2WD CC)... Anyone go the taller springs route? Same duty rating as stock, but just taller coil springs in front to level it out??? If so, where'd ya get 'em? Who makes 'um? How much were they? etc etc etc... Thanks!!!
Daryl
Old Nov 14, 2004 | 12:24 AM
Greg250's Avatar
Greg250
Look in my gallery, mine has the factory snow plow springs which make it sit level.
Old Nov 14, 2004 | 08:39 AM
Badford's Avatar
Badford
check my gallery...i have a nixon perf 2.5 front hanger kit with a ford 4" rear block..
Tony
Old Nov 14, 2004 | 09:50 AM
mgood's Avatar
mgood
fabtech 3.5" hanger kit with 33" tires, nothing done to the rear. Check it out.
Old Nov 14, 2004 | 11:59 AM
Sparky04SD's Avatar
Sparky04SD
Mine is in my gallery and has an Edge mini spring pack in front and 4" blocks in rear. I run 315's (35") on 16x8's.
Old Nov 14, 2004 | 12:36 PM
Antelope V-10's Avatar
Antelope V-10
In my gallery, Rancho 2.5", 4" blocks, 265's
Old Nov 14, 2004 | 06:55 PM
77hiboyboy's Avatar
77hiboyboy
Where do you get the edge mini spring pack?? I've looked at your gallery a ton and can't find the lift you have. Cost if you don't mind saying??
Old Nov 14, 2004 | 08:12 PM
UnderTakr's Avatar
UnderTakr
I just bought a Spring that was arched 3 inches and installed it under the front springs and then replaced the 2 inch block witha 3inch one. The truck sits level and a bit higher!! All for the price of 186 bucks!!
Will post pics later!!
Old Nov 15, 2004 | 08:56 AM
dmgiff's Avatar
dmgiff
I'm also looking for info on this. I have an 04 F250 PSD CC 4wd and put 295's over the weekend on it, which slightly rub when turned full lock to the left. I am going to put a leveling kit on and 4" blocks in the back. Question is, which leveling method? Tuffcountry makes a kit for $280 that has what appear to be mini spring packs that go under the stock springs and a track bar relocator bracket. Is this an acceptable method? The other option, which appears more expensive, is to get new springs. I want to install it myself. I don't do heavy off roading, but a little bit, hunting/fishing/atv, etc. Any help?
Old Nov 15, 2004 | 09:21 AM
mizzitch's Avatar
mizzitch
I have a 1999 F-250 Super Duty V10 that came with the 4400# rated front leafs. I replaced the factory front leafs with the 5200# rated leafs. It rides a little rough, but looks a lot better. I was lucky with the rear height b/c Ford decided to use the 3.5" spacer blocks on some F-250's and mine was one of them. I've got some pics on this web page -> http://personal3.stthomas.edu/MLMALECHA/
Old Nov 15, 2004 | 09:34 AM
dmgiff's Avatar
dmgiff
Why did you choose to do that method instead of purchasing one of the kits? Is that all you had to change? You didn't have to change the track bar bracket or anything else?? And did you buy Ford springs or aftermarket springs rated for that weight? I would prefer to keep a near factory ride, but I'm not totally set on that. Thanks for the info.
Old Nov 15, 2004 | 09:52 AM
mizzitch's Avatar
mizzitch
I thought it would be cool to have the added capacity in case i wanted to plow in the future. The springs were all I changed, but I am looking into an adjustable track bar. My new leafs are the Ford Snow Plow Package leafs - from the parts counter.
Old Nov 15, 2004 | 10:19 AM
dmgiff's Avatar
dmgiff
How much were those if you don't mind my asking?
Old Nov 15, 2004 | 10:39 AM
Badford's Avatar
Badford
if you want the factory ride, buy the drop hanger kit... i also recomend the adj trac bar NOT the relocating bracket...i have the relocating bracket and i have bump steer.... i will be purchasing a adj trac bar soon...
