antennae options
Old Nov 13, 2004 | 06:26 PM
88grandmarquis's Avatar
88grandmarquis
antennae options
Wondering if anyone has done anything different with the antennae on their truck. Anyone ever put a power antennae in place of the factory one? If so, where did you get it and how did you hook it all up?
The one on the truck is a bit bent and usually clips the garage door when driving in and out.
Justin
'86 F-150 XLT
Old Nov 14, 2004 | 05:38 PM
Cheggie's Avatar
Cheggie
There's not enough room below the cowl to install a power antenna in the stock location. If I were you, I'd either: get a higher garage door, or get a slightly shorter antenna at the auto parts store. There are aftermarket replacements that will thread onto the stock antenna base. Or cut a few inches off the one you got!
