99 EB blown spark plug
Old Nov 13, 2004 | 11:09 AM
CyberEagle's Avatar
CyberEagle
I just paid $500 to have the number 3 spark plug and coil replaced after it blew out of the head at 64,000 miles. It was repaired with a heli-coil. Does anyone have any experience with the effectiveness of this repair? Should I expect this fix to be permanent or recurring?
99 Exedition EB, 5.4L
Old Nov 13, 2004 | 01:57 PM
xxx609's Avatar
xxx609
Installed correctly, Heli-coils should be permanent. They are a common cost effective practice in the automotive world. Hopefully, the person installing the new sparkplug in the Heli-coil didn't cross thread it. That's probably why the original plug blew out.
Old Nov 14, 2004 | 12:03 PM
CyberEagle's Avatar
CyberEagle
Wink
Thanks for the vote of confidence. I had the dealer perform the repair, so I am hoping that they knew what they were doing. I hate driving around with the thought of a potential re-occurrence of the problem looming in the back of my mind.99 Expedition EB 4x4 5.4L
Old Nov 14, 2004 | 10:24 PM
MisterCMK's Avatar
MisterCMK
The original plugs blow because the head is weak. Not because they are cross threaded. It is actually quite a problem on these motors, the 4.6, 5.4, and the V10
Old Nov 14, 2004 | 11:23 PM
rstark05's Avatar
rstark05
Talking replace popped plug 97 expy
I just replaced my #4 plug and coil myself after the dealer quoted me $3700 for new head or $6000 for new engine. Thanks to this site I found the solution. After extensive research here (there is a bunch of info on the subject as it is a common problem) and talking to mechs, they recommended against helicoil. They suggested a steel insert. Said the helicoil was not goining to hold long in the aluminum head. I used a steel insert from TimeSert. They call it the Triton Bigsert kit. It was a bitch to do, but it has been running fine since.
In your case if the Helicoil goes you can still use the insert.
good luck
97 Expy 2wd 5.4L
Old Nov 15, 2004 | 09:58 AM
MOOK929RR's Avatar
MOOK929RR
has anyone had a this blowout prob in an expi 2000 or newer? i thought this problem with the weak head was only in 97 - 99 models....
Old Nov 15, 2004 | 12:24 PM
MisterCMK's Avatar
MisterCMK
My 2k Eddie Bauer had the plug blow out in North Platte nebraska, 800 miles from home.
Old Nov 15, 2004 | 06:37 PM
xxx609's Avatar
xxx609
I regret having used a trade name, "Heli-coil" (there are many others); I should have used it's generic equivalent "threaded insert."
Old Nov 15, 2004 | 07:07 PM
99 Navi Guy's Avatar
99 Navi Guy
Hmmmm? ...... Would it be good practice then to be very careful not to over-torque the plugs at time of replacement as well as use an antisieze compound?
Old Nov 15, 2004 | 08:33 PM
MisterCMK's Avatar
MisterCMK
I wish there was a way to prevent it from happening, but there isn't. When I replaced my plugs, I did it by the book. The plugs can also blow out of the head even if they are original plugs, so that leaves me to believe that the threads are weak in the modular motor heads.
Old Dec 17, 2004 | 10:35 AM
lospinoj's Avatar
lospinoj
My #3 popped out a few days back, these are the original plugs at 104K, weighing out my options, this seems like it's at least worth a try. Can this be done without removing the head, and by a do it yourselfer, with decent mechanical skills but by no means a prefessional mechanic ?
Old Dec 18, 2004 | 12:09 AM
gkbid's Avatar
gkbid
You don't have to be a master mechanic... Take your time and follow the instructions, as long as you can get sufficient access to the plug bore you have nothing to loose ... and serious money to save!
Good Luck.
Old Dec 21, 2004 | 08:10 AM
lospinoj's Avatar
lospinoj
#3 Is Burried
I had a (2) techs look at it only to tell me that with the amount of labor involved just to get access to the whole, I might as well invest in the full head replacement. On the passenger side, the two back cylinders are buried.
Old Dec 21, 2004 | 08:47 PM
CyberEagle's Avatar
CyberEagle
That's what I thought at first - that it would take days to fix the #3 plug, but the dealer did it in less than 2 hours (although they charged me for four quoting "standard book rates"), without removing the head. I'm not sure they could do it as quickly on the #4 plug, which is, as you said, buried in the back. The heater hoses have a quick disconnect feature that allows them to be removed pretty quickly. The rest of the tubing and wiring can be moved to the side giving access to the plug bore, but you still need to work in a pretty tight space to get the bore tapped.
Old Dec 22, 2004 | 06:25 PM
gkbid's Avatar
gkbid
#4 is not accessible... you'd never be able to use the insert installation tools, but #3 is accessible. This thread started out with the gentleman stating he had a dealership put an insert in #3, and they did it in only two hours.
Again, I suggested spending the $40 for the insert kit and trying it... only $40 and a couple of hours to loose... and hundreds (or thousands) to gain.
