95 Ranger clutch switch
Old May 12, 2002 | 02:49 PM
fordson's Avatar
fordson
Can the clutch disengage switch be bypassed? At times, all my truck will do upon trying to start is a clicking sound like a solenoid picking up. If I let off and depress the clutch again, sometimes 5 or 6 times, it will finally crank up.
Gary
Old May 13, 2002 | 12:34 PM
Ken00's Avatar
Ken00
If the starter solenoid is clicking then the clutch switch is working properly. I would suspect a battery, connection, cable problem.
Old May 15, 2002 | 10:15 PM
proford460's Avatar
proford460
also make sure that you don't have a floor mat under clutch pedal
look up under steering column at clutch sw for sign of brake fluid leaking in it will wreck sw.
Old May 15, 2002 | 11:13 PM
302Ranger's Avatar
302Ranger
