will a nine inch fit
Old Nov 12, 2004 | 03:19 PM
rick estep's Avatar
rick estep
i have a 81 f-150 with a ford nine inch with a locker and i would like to know if it will bolt right in to place on my 85 f-150. the 81 is a parts truck. any awnser or comment would br appriciated.
Old Nov 12, 2004 | 03:57 PM
SRD4X4's Avatar
SRD4X4
Yes,right in.
Old Nov 12, 2004 | 07:26 PM
8 Lugs's Avatar
8 Lugs
Just curious, what type of locker is it?
Steve G.
Old Nov 12, 2004 | 09:09 PM
rick estep's Avatar
rick estep
reply to locker
Steve G.
the tag off the pumpkin states that its a 2L75
the tag reads as follows: top line fb ba 1d16
bottom line 2L75 9 s 315b
i contacted the local dealer and they stated that it is a locker with 2.75 gear ratio.
again thanks
Old Nov 12, 2004 | 09:23 PM
mustange70's Avatar
mustange70
It would be a limited slip, still a pretty good thing to have.
Old Nov 13, 2004 | 04:40 AM
8 Lugs's Avatar
8 Lugs
A "Limited slip" is clutch type traction aiding differential that "encourages" both wheels to continue turning at the same speed when traction on one is lost. These differentials require a "friction modifier" added to the gear oil to enable the wheels to turn at different speeds when cornering to eliminate clutch chatter.
Ford calls them "Trac Loc"-"Traction Loc"."Power Loc"
Chevys are called "Positraction" or "Posi" for short
Mopar called them "Sure Grip"
A "Locker" is a mechanical lock-up differential with out spider gears or clutches. When cornering the vehicle is driven only by the inside wheel. When enough power is applied, the driving wheel will break traction and rapidly gain speed until it's speed matches the undriven axles speed. At that time it will mechanically "Lock" to the other axle. Both axles will turn at the exact same speed until power is removed.
"Lockers" do not require a friction modifier additive because they have no clutches.
To unknowingly drive a vehicle with a locker, you will swear there is something wrong with the rearend!
To my knowelege, Ford only put these in some muscle cars of the 60's, marketed as a "Detroit Locker" and some HD trucks of the 80's, marketed as a "No Spin"
Steve G.
