help with headlights
Old Nov 12, 2004 | 10:28 AM
jgoshow's Avatar
jgoshow
have a 92 f-250 diesel...high beams work but no low beams...i do have a plow hook up....what could this be?
Old Nov 12, 2004 | 11:16 AM
5_labsownus's Avatar
5_labsownus
Did you cut or splice into any light wires while installing the plow?
If not I would say the beam selecter switch is bad. The High beam wire should be Lt. Green and Black. Check for power out of the switch.
