Sponsored by: Auxito
Adding power windows/locks
Old Nov 12, 2004 | 09:21 AM
kedwinh's Avatar
kedwinh
I would like to add power locks and maybe power windows to my 97 F150. Any one have any suggestions as to the best way to do it?
Thanks
Keith
Old Nov 12, 2004 | 03:15 PM
BillyBob69's Avatar
BillyBob69
There are aftermarket kits available but they do take a bit of electrical and mechanical knowledge. For the locks, you will have to install an actuator inside the door that connects to the lock rod, then you will need to wire it. Also will need to install the lock switches in each door. For the windows, install motor and wiring and switches. Now the motors will connect to the gear that the handle crank uses. They aren't that bad to install really, but for first timers...it can be quite a project. You will need to drill holes though the inner door panel to mount the motor and actuators, feed wiring through the boot that attaches from the door to the fender. Locate power sources, cut holes in your door panel for the switches...etc. I used to do those for a living and after awhile it was pretty easy...but the first ones can take a better part of a day if you haven't tackled anything like that before.
Old Nov 13, 2004 | 05:07 PM
kedwinh's Avatar
kedwinh
Thanks BillyBob...I haven't don't this before but have done alot of automotive wiring on jeeps and hotrods. I was thinking about factory window motors and door panels and maybe locks also. Just not sure if the wiring harness is there or not or if I need to grab it from the wrecking yard also.
Keith
Old Nov 14, 2004 | 03:21 PM
BillyBob69's Avatar
BillyBob69
Only way to find out is to pop the door panels off. Good luck and let us know if you need any other info.
Old Nov 17, 2004 | 04:50 PM
DjThomasJ's Avatar
DjThomasJ
how can i find the motors that attatch to the manual door gear like u posted billybob ? im doin a power doorlock/window conversion on my 03 xl sport but im using the factory doorpanel adn switches.. all i need is the power gem module and some harness's , ive already installed actuators .. just gotta worry about the power window part of it after all that other stuff
Old Nov 18, 2004 | 09:49 AM
BillyBob69's Avatar
BillyBob69
Here is a link to one of the major manufacturers of power window kits and aftermarket stuff.
http://www.spal.com/automotive/engli...FTERMARKET.htm
Just do a web search for power window kits. There are tons of em out there.
Old Nov 18, 2004 | 10:30 AM
DjThomasJ's Avatar
DjThomasJ
thanks!
Old Nov 18, 2004 | 10:34 AM
BillyBob69's Avatar
BillyBob69
By the way.....should you decide to do an OEM style install...(The link I gave you earlier also sells OEM), here is a great link for the installation. Step by step with pictures.
http://www.obdcodes.com/howto/powerwindows.php
Old Nov 18, 2004 | 10:39 AM
DjThomasJ's Avatar
DjThomasJ
yah i think im goin OEM.. those aftermarket ones seem a bit high priced and i can do it all pretty cheap .. i have a friend that works at ford as the service parts manager so thats where im getting the new gem box.. and door panels with switches... harness's from junk yards for 30 each (dealer wants 228 for each one) and then the window regulators and stuff probably both for 50 (tahst how much i found them for and actually one the auction, but the dude sent someone else my front window regulators w/motors to someone else and had the rear ones left so it was a big mess but i got my money back) but im sure i can find some at a good price again...
Thanks
-TJ
