power steering conversion question
Old Nov 12, 2004 | 01:16 AM
nlee1188's Avatar
nlee1188
Cool power steering conversion question
I have a 1976 F-150 4x4 360 that I would like to convert to power steering, as it is become very difficult to steer. I got a power steering pump and steering box out of a 77 150 from the yard and it doesn't fit. My question being: what do I need look for ie.. year model ect.. To match up boxes? Am I even asking the right Question, and any suggestions please. I thank you in advance for your help.
Nancy Lee
Old Nov 12, 2004 | 05:06 AM
SRD4X4's Avatar
SRD4X4
76-77 f100,f150 4x4 use same parts,maybe the truck you got parts off wasn't a 77. What doesn't fit,box dimensions,bolt holes,..?
Old Nov 12, 2004 | 06:54 AM
Nod's Avatar
Nod
Power Steering
nlee1188,what type steering does your truck have on it to start with?That will help to tell what is needed to answer your question.
"bowties in the rearview mirror"
Old Nov 12, 2004 | 11:27 AM
nlee1188's Avatar
nlee1188
Question
Hi guys
The type of steering that I have I believe is called assisted (it has a shock running horizontal to the ground) I was told that the new box out of the 77 was too short meaning there are two different size boxes??? I'm sure it would help if I knerw exactly what I was talking about but thi is the best I can Do. Does a hollander number 1088 help? It's a cross reference number I got from that parts guy at the junk yard.???
Old Nov 12, 2004 | 03:53 PM
SRD4X4's Avatar
SRD4X4
If you have power assist now,then the box is actually a manual.I don't think F-150's had this set-up after 75.But I could be wrong and am sure someone will correct me if I'm wrong.Are you sure that's not just a steering damper?
Old Nov 12, 2004 | 08:03 PM
Nod's Avatar
Nod
Power steering Conversion
nlee1188,send me your e-mail address using the information when you click on my username and I will send you a download of the article I wrote on how to convert your truck to the newer integral box power steering.This gets rid of the ram and manual steering box and replaces it with a 78-79 F-150 power steering box with a fair amount of work it can be done in a few days.Good Luck.
PS-have you checked your inbox lately? I thought I already sent that article to you but I could be wrong.
Old Nov 13, 2004 | 12:12 AM
Stock78's Avatar
Stock78
Keep in mind that a 4x2 steering box is reversed from a 4x4 steering box, at least in the 78-79 years. The Pitman arm comes out on the front on a 4x4 and in the rear on a 4x2. Kind of narrows down the choices..
Someone please correct me if I am wrong. If I am wrong, I'll be happy since it will make it easier to find a new box for my 4x4..
Isaac
