Error code #18, what should I do?
Old Nov 11, 2004 | 10:04 PM
Ranman86F250's Avatar
Ranman86F250
Cool Error code #18, what should I do?
I cannot start my '86 F250 302 EFI (cranks and cranks but no start). In addition to a couple of temp sensors out of range (code 21 & 24), I have code 18 showing on the reader (Loss of tach input/ignition diagnostic monitor - circuit failure/spout circuit grounded). I have not found any problems with the wiring. Should I replace the TFI module, or is there a test I can perform to test it before I yank it? I'm getting spark, I seem to have fuel, this is really beginning to **** me off. I'm ready to drive it off a cliff but I have to get it started first!
Old Nov 11, 2004 | 10:26 PM
88grandmarquis's Avatar
88grandmarquis
My '88 Grand Marquis (EFI 302) did that to me last winter. Cranked and cranked, but no start. New TFI module fixed it.
Old Nov 12, 2004 | 04:14 AM
locknkey's Avatar
locknkey
You are gonna waste your money...fix the other problems Codes first. It will fix the whole solution as other parts effects other codes problems.....
Old Nov 12, 2004 | 11:30 AM
5_labsownus's Avatar
5_labsownus
The code 21 & 24 are showing up because the engine is not at operating temp.
Old Nov 12, 2004 | 10:12 PM
Beast12's Avatar
Beast12
My truck runs perfectly fine but I also have a code 18. There have been a few posts on here about it but there does not seem to be an answer for it. It is weird. I have even tried to disconnect the battery as well but no luck.
-Matt
Old Nov 14, 2004 | 01:54 PM
Ranman86F250
Update! Well, I could have and should have listened to Locknkey's advice. I replaced the module and of course, no change. While checking to make sure the rotor was turning, while hand-turning the engine, I found excessive play in the timing chain. I thought I'd better check the timing, as I now had an idea what was wrong. Sure enough, the timing was way off. I corrected the timing, got the engine to start and run but it was rough. Pulled the front timing cover off and found a very loose, bone dry timing chain. The sprockets were off by a couple of teeth, which was my whole problem. There is so much sludge in the motor that no oil was getting to the chain. I'm hoping to figure out where the oil path is and clean it before installing a new chain. Needless to say, I am very relieved to have found the problem and know that I can correct it relatively easily and cheaply.
Old Nov 14, 2004 | 04:55 PM
Beast12's Avatar
Beast12
BUT, do you still have the CODE 18?
-Matt
