Anyway to get heated seats in my 05?
If you have the truck, then it's not a cheap change. There was a topic on this a while back, and since the heated seats are wired into the heating system it requires a lot of changes other than just the seat itself. The seats are wired for heat before Ford gets them - it's not added in at the factory. If I remember correctly, this is the summary of the prior thread.
Jeff, thanks for your reply. I have found a set over on the dieselstop that seems to get very positive comments. I also appreciate the comment on "if he can do it..." that is the part that has me hung up, but it sounds like it is doable, so I will take the plunge on behalf of my wife's backside. Thanks
Phil
Phil
